Looking at a Tired LS1 -- Need Some Opinions
I'm about to hit 200K on a 2000 Z/28 Automatic. I like the car and would like to restore it, but I don't want to pay more than a new one would cost.
The engine is still running okay, but needs something (probably a lot of somethings). But, the engine is my first priority.
Since I'm stuck in California, I can't do much to it, but I'm pretty happy with stock. Is it better to find a wrecking yard/second-hand engine, buy a new/remanufactured engine, or tackle a rebuild myself, replacing all rotating assemblies and most other internals? When I rebuild, I get cylinders matched to the pistons, cam align-bored, forged pistons, new rods, etc. Years ago, it was better to do rebuilds, but machine shops are rare as hen's teeth now.
If someone has done this job recently (especially, in CA) I would like a thumbnail guess on cost.
I hope this isn't too tedious. Thanks, in advance!
jeff
jeff
Jeff,
If your happy with the stock configuration and power, I would stay with the stock piston, rods,etc. I would open the engine up and check for damage to any of the above mentioned parts. If no damage is evendent. I would just look at replacing bearings, rings, and hardware like lifters and pushrods. No sence it spending extra on forged internals if don't have to. Just my .02
Ken
Ken
Thanks, Ken. I usually don't re-use pistions, but I guess cast would be good enough. I get into enough trouble with it as it is. :-) It's tempting, though, to pick up one from a wrecking yard, but I would wonder how it was treated. I have yet to find a rebuilt one that was anything close to reliable. Just lots of unknowns. I heard that the newer blocks fixed the way the PCV Valve works (that insane plumbing nightmare on mine is supposedly gone on the newer LS1s, but I don't know that personally).
Thanks for the input.
jeff
jeff
Jeff,
Ken
Ken
Good Idea Ken.
As far as the OP...... Good stock rebuild and you should be good to go for years!
Jeff,
Give us a call, We have options to rebuild your existing motor or build all new. Our builds go from performance stock replacement to full race and everywhere in between.
Thank you for the recommendation MMorgan9812, We appreciate our name being put in the mix when people are in need. It gives us the opportunity to help more of those in need of an excellent product.
