Blueprinted Melling 10296?
Is there any real need to do this?
This is what is done:
All passages have casting flash removed, corners radiused and polished to Increase GPM Flow. The Housings & Gears are then De-burred by a vibratory polisher to Reduce Wear and Cavitation. The Gears are then prepared and sprayed with TECH-LINE moly-coating to Reduce Friction or HP Loss. Three Critical Clearances are checked on reassembly;(1) Gear to Housing, (2) Mesh or Backlash, (3) Gear to Cover-Plate. The relief-valve is De-burred with emmory cloth to insure smooth operation, cleaned and is re-installed with the existing spring and new hardware. Each cover plate is also Vibratory Polished, cleaned and fastened with safety_wired aircraft bolts. All pumps are bench tested.
And the obligatory picture:
Small block chevys have always had great oiling systems and I tend to get into it with stock car guys all the time that believe you need a high volume big block pump and 20w50 or straight 30/40 oil in engines. WHY ???
A massaged standard volume/higher pressure pump and thinner oil will always make more power and have enough oil feed at any rpms if the clearances are correct.
In his Big Block Cobra Engine Builds for over 15 years and swears
By them. Absolutely at the top of my build list. For any engine
Spinning 6500+ RPM the protection from Cavitation is absolutely
Worth the Money!
The owner of precision oil pumps claims in addition to improved oiling,reduced aeration & cavitation, on a built LS Engine They have measured 7-8 Crankshaft HP increase swapping out the stocker On a Dyno above 6000 RPM.
http://www.schumannsdynamicperforman...nment-kit.html
Unless requested. Different bolts are used in assembly
Hopefully the maker will be able to chime in.
The moly stuff they're spraying on comes in an aerosol can and can be had for less than $15....
With that said,I use a Melling 10296 on my LME $15k engine. LME blueprinted it when they built my engine.
On my low dollar sub $5k engine build,I'm using a ported m295 becuase it's less than half the price.
Any oil pump can be setup to have acceptable idle oil pressure with loose clearances. ANY OF THEM.
The 10296 is actually cheaper than the ported LS6 stuff. And only a few bucks more than a stock LS6 pump. The M295 is a good replacement for the LS6, but it's not a high volume pump. And there is a difference between "higher pressure springs" and more volume. Typically, more volume makes more pressure by the influx of additional oil being forced through the same sized clearances...
