First time head swap
Old Aug 1, 2015 | 05:01 PM
LS1TA76's Avatar
Default First time head swap
Hello
I am about to do my first head swap for my Ls1 76 trans am ..
I just need to know what kind of special tools ill need for this process becuase i live in a place where i have to order everything online.
So what i have on my cart now is:
Tourqe wrench 20 to 150 lb
Angle gauge
Feeler gauge
Head swap gasket kit
I just want to know what i am missing so i dont have to order and wait another week again
Thank you.
Old Aug 1, 2015 | 08:19 PM
Darth_V8r's Avatar
Moderator
Get a good assortment of extensions for your ratchets. I have two 18" ones that come in very handy with head work.
Get one of those 11" body boards for sanding body work to clean up the heads.
A good digital caliper.
Will the heads come prepped? If not you'll need valve spring compressor.
Old Aug 4, 2015 | 08:42 AM
mikesimpalass's Avatar
I'm speaking from experience here. blow the head bolt holes in the block out with compressed air, then take an old head bolt, grind two flat spots in the threads, then use that to chase the threads in the block.
Old Aug 4, 2015 | 08:58 AM
Darth_V8r's Avatar
Moderator
I ended up using thin strips of paper towel twisted up to insert into the holes and soak up the coolant as well. I couldn't blow all the coolant and oil out, but once it was basically empty, the air dried them pretty well.
Old Aug 4, 2015 | 09:29 AM
svede1212's Avatar
I didn't see new head bolts. The stock ones are use once. If you are ever going to do it again get ARP which can be reused or if you have the bucks get ARP studs as it's the best for an accurate torque and being nearly impossible to grind the threads in the block.
Old Aug 4, 2015 | 11:43 AM
gagliano7's Avatar
Use a straw taped to the end of the shop vac to suck out the bolt holes. The straw from dunkin donuts worked fine. I had all my holes dry in 5 minutes. Blowing it out doesn't work so great and the paper towel are a pain. I just checked for dryness with some long q-tips. To me the absolute worst part was cleaning the deck on the block. Everything else was pretty easy.
