Stroker help - will this rod work
Old Aug 3, 2015 | 02:06 PM
70GS455's Avatar
Default Stroker help - will this rod work
Hi All. This is a GM question although not strictly a Chevy so don't hate. I'm wondering if this LSx rod will work in a Buick 455 stroker project:
http://www.ebay.com/itm/Eagle-H-Beam...-/190781630941
The main question I have is will the small end survive being opened up to the Buick pin size of 1.00" (from 0.927").
Operating conditions will be no more than 6000 rpm, approx. 600/600 hp/ft-lb, heavy piston (about 975g).
I plan on offset turning the crankpin down to 2.1, widening the crank sides, and running the LS rod bearing.
Any help is appreciated.
Old Aug 3, 2015 | 09:59 PM
usdmholden's Avatar
I would not. You will be cutting .037" per side on the small end and running a piston more than twice as heavy as the typical LS1 piston.
Cutting crank pin should not be a problem but you need to make sure the big end widths match the crank.
Prob can work with custom .927 pistons.
