torquer v4 cam or v2
Old Oct 15, 2015 | 09:03 PM
99yellowz28's Avatar
I have the v3 in my car once you get over around 3k you can feel that cam pull. I have the 111 lsa sounds really good
cosmo01's Avatar
Yes i went with the v4. Put in a 3600 yank,hi-performance oil pump waiting on timing chain possible it could be done this weekend
Old Oct 15, 2015 | 09:11 PM
Did you do the trunion bearing upgrad? That's a cheap good upgrade while yourin there
Old Oct 16, 2015 | 01:04 PM
RollinSScamaro's Avatar
Cosmo sounds like a good set up, let let me know how it does at the track and dyno numbers. Can't find a ton of info on track times especially.
Old Nov 6, 2015 | 09:35 PM
cosmo01's Avatar
Default micky ts or nitto
I got my car back after cam and stall now i need tires,not sure what would be better for mostly street with a few stops at the track each year. What does every one have the most luck with?
Old Nov 6, 2015 | 09:54 PM
HCI2000SS's Avatar
Some type of drag radial for sure. Some wear faster than others. Have a mileage in mind?
Old Nov 6, 2015 | 10:08 PM
cosmo01's Avatar
No its more of a toy we only take one three hour road trip a year with it
Old Nov 6, 2015 | 10:21 PM
HCI2000SS's Avatar
If you don't care much about handling then something like a MT drag radial will work well. There's others as well
Old Nov 7, 2015 | 11:45 AM
I'd go with the MT drag radial.. wears faster but hooks way better than nitto 555r. I have never had any luck with nittos honestly, some people do. Any tuning or dyno numbers with the v4 yet? Which heads did you go with also? Not sure if you mentioned that yet.
Old Nov 10, 2015 | 08:59 PM
cosmo01's Avatar
Default today was dyno day
she put down 412 rear wheel hp speed inc said i can pick her up in the morning, pretty sure i wont sleep haha
Old Nov 10, 2015 | 09:54 PM
412rwhp with stock 241 heads and bolt ons? Those are great numbers going through a stalled auto.
Old Nov 11, 2015 | 11:05 AM
  #32
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Thanks for the update. Let me know how you like that cam. It should pull hard.
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Nov 11, 2015 | 11:38 AM
  #33
UNLEASHEDWS6's Avatar
on stock wheels 315 is pushing it. I just went thru this same thing and swapped to 10.5" wheels to get 315/35/17s on the rear.
Old Nov 11, 2015 | 10:20 PM
  #34
cosmo01's Avatar
Did you go with nitto or mickey ts
Old Nov 12, 2015 | 12:57 PM
  #35
i went the cheap route for now
17x9 AR605 torq-thrust on the front with 275/40-17 sumitomo thr z II
17x10.5 AR605 torq-thrust on the rear with 315/35-17 toyo proxes tq ll
not sure how the toyos are going to work yet but for the money it was worth a try for me
Tire Rack $185.21 each
the whole package shipped to my door $1,583.12
Old Nov 12, 2015 | 10:28 PM
  #36
Mike94ZLT1's Avatar
Originally Posted by CaliboyTA
i have a torquer v2 with a 112 lsa and its a great cam. the cam doesn't really shine until around 4k rpm and then it really pulls till redline, however it does develop a low rpm "bucking" which is annoying as hell
You have a shitty tune then. With a good tuner that cam has very few driveability issues.
Old May 3, 2016 | 06:32 PM
  #37
cosmo01's Avatar
Default suspension??
what would help me hook up besides tires, i was thinking subframe connectors and some kind of traction bars any advice?
Old May 3, 2016 | 09:03 PM
  #38
Subframe connectors, Lower control arms, adjustable shocks to help transfer weight, short adjustable torque arm. All of those items will help keep the wheels planted. You get the car out to the track yet? How is driveability so far?
Also you said 412rwhp. Was that with stock 241 heads? How about the intake? Ls6 or fast?
Old May 6, 2016 | 09:15 AM
  #39
cosmo01's Avatar
sorry for the delay no track yet. the car has stock heads and stock intake. its ms3 cam with full exhaust,cold air lid and a really great dyno tune.
Old May 6, 2016 | 10:38 AM
  #40
whatsa347's Avatar
So you didn't go with the V4 you said you had installed?
