Best heads an cam for stock ls1 engine
Old Sep 20, 2015 | 11:19 AM
  #61
96capricemgr's Avatar
Originally Posted by powellmachine
my cnc 243/799 flows 312 with a 209cc int port, I charge $1150 with you supplying cores. and that's ss valves, pac 1218's, serdi v/j and milled, and my cams are $365.00, just sum pricing info for comparison.
Troll, heads have smaller than stock ports but flow more than what actual reputable shops and all your prices are cheaper.
Old Sep 20, 2015 | 12:12 PM
  #62
Darth_V8r's Avatar
Moderator
Not sure I follow that. That's in the range of the Mamo 220's. Under what conditions, lift, bore, etc? What about lower lift flow, port velocities, efficiencies, etc?
I know Tony aims for 1.45 port efficiency and gets that on the 220's on a 3.9" bore. Your numbers are 1.5 port efficiencies on a stock casting?
My old ported heads were reported by the speed shop to flow 285 at 600 lift, and the best I ever got off them was 370 horsepower.
Old Sep 20, 2015 | 09:03 PM
  #63
Project_Reaper's Avatar
So I just bought this MS4 cam with 7.4 PRs for my stock ls1 with 241 heads...well I just found a nice set of stock 243s and I was wondering will I be able to use them with the cam package or will i have to fly cut the pistons?....or should I just check ptv and then make that call?
Old Sep 21, 2015 | 01:07 PM
  #64
powellmachine's Avatar
typo, they are 234cc,, stock is 208cc, no troll's here
