Quickest Way to 500hp with 6.0
Next Quickest way is a pro charger. If you want to stay NA, call tony Mamo
If you go HCI, you'll be hard pressed to hit it and stay in budget. Aftermarket heads make a big difference. Plus you don't want to go cheap on supporting hardware like lifters, pushrods. Especially for a DD 500 horses. If you want performance and dependability you will need to pay for it.
The above description is why I went HCI instead of going 408. No matter what you do you need to do the top end work.
I would go to Tony for the heads, no question. The rest can be speced out from there.
Spend the rest on a good clutch/exhaust/induction system, ftp 104mm, straight hose to 102mm tb (SD), and chrs1313 or ssra ram air. For headers get speed engineering 1 7/8, and a vibrant or flowmaster 3 to 4 inch collector, and a 4 inch cut out. You will need to fabricate a custom y pipe. Oh and you will need a good fuel pump like racetronix and 36 to 42 lbs injectors.
You should hit 500whp with this
A stroker still needs a good topend. Displacement is the most expensive way to add power once you go beyond factory displacement options.
$4000 for heads/cam/intake can on the lowend get you 100+rwhp, $3500 in a 408 shortblock with the same heads and cam might only gain you another 20-30 but would improve manners.
You mentioned LS3 intake with 243s, aint gonna happen.
What is the most powerful car you have driven and what are the performance goals? 500rwhp should do mid 10s, rollbar and all that crap, wont hook on street tires below 50mph etc.
And when I get ready for heads what exactly do ineed to look for? like cc's wise because I am not 100% educated on heads and compression ratio, but I am trying.
Otherwise, a 500rwhp NA build on a 6L is doable, but not for $5k. And it's not exactly reliable - but it's not bad. You have to service the valvetrain much more regularly to ensure everything is holding up (mostly the valve springs).
Used FAST 92/102, 90 MM TB, New CAMMOTION 231*/235* .610"/.590" LSA 114*+2* used 1 7/8" ARH, Kooks LTs, 36lb-42lb injectors, 11.0-11.5:1
Compression, EWP not necessary at this point. Definitely have heads checked
Out, and if the deal is good enough have Tony fresh them up and port the FAST Intake. 347" have cracked 500 RWHP with AFR205s and all the
Little details. 366" with 225s and a moderate cam should be able to do it
A lot easier.
