New engine build, first start, oil everywhere
Old Aug 20, 2015 | 10:31 PM
z28mobbin's Avatar
Default New engine build, first start, oil everywhere
So I built the motor to drop into my gto. Gen iv lq motor, at first start up the engine puked oil all out the back of the engine. Oil pan looks dry. Any ideas on what to check? I'm just feeling like **** now that I've invested so much money and time and now I'm back to square one. Yay I get to pull the tranny again -__-
Old Aug 20, 2015 | 10:34 PM
KCS's Avatar
KCS
Moderator
Did you forget the rear main seal or something?
Old Aug 20, 2015 | 10:40 PM
z28mobbin's Avatar
I put the rear main seal in. I remember pressing it into the rear cover.
Old Aug 20, 2015 | 10:53 PM
KCS's Avatar
KCS
Moderator
Try looking behind the manifold for the oil pressure sending unit.
Old Aug 20, 2015 | 11:30 PM
kinglt-1's Avatar
^This!
Old Aug 20, 2015 | 11:57 PM
z28mobbin's Avatar
Oil pressure sending unit. To see if it's installed? Or what should I be looking for? I installed it but it didn't look like it was right. It was just threaded into the valley cover. In the back but not actually in the block itself. Hopefully that's all it is.
Old Aug 21, 2015 | 12:02 AM
z28mobbin's Avatar
This is the motor before it went in. Pressure sensor looked kinda funny to me, is that right? It's a gen iv lq4 with donor parts from the 04 gto.
Old Aug 21, 2015 | 12:52 AM
z28mobbin's Avatar
So could it be the valley cover i uave installed is wrong amd allowing oil to leak from the top? I felt around the oil pressure sensor and i can feel oil back there so it has to be coming from that area.
Old Aug 21, 2015 | 01:01 AM
KCS's Avatar
KCS
Moderator
Yeah it's possible. I just don't think a whole lot of oil gets up there though. The OPSU however is fed pressurized oil so if the seal is broken or the sensor isn't tight, it would dump a lot of oil quickly.
Old Aug 21, 2015 | 01:05 AM
z28mobbin's Avatar
Ya it was a lot of oil and the car only ran for maybe a minute. It made a pretty big pool under the car. So I'll have to double check that and make sure it's installed correctly. Idk how it's supposed to read the pressure if it's not threaded in the block???
Old Aug 21, 2015 | 01:43 AM
KCS's Avatar
KCS
Moderator
Did you have pressure on the gauge?
Old Aug 21, 2015 | 04:05 AM
natejk's Avatar
I had a k&n oil filter do that to me blew out the bottom pissed oil everywhere new non k&n filter never had that issue again
Old Aug 21, 2015 | 05:04 AM
joecar's Avatar
What valley cover do you have on there...?
Old Aug 21, 2015 | 10:51 AM
z28mobbin's Avatar
The display said low oil pressure. Probably spit out half the oil. Any other things I should check out? I'm gonna disassemble top of the motor (intake, Valley cover etc) to make sure it's not leaking out of the pressure sensor hole. Hopefully that's all it is.
Old Aug 21, 2015 | 01:00 PM
shoeboxvette's Avatar
Possibly the wrong gasket for the valley cover?? They have a couple of designs.
Old Aug 21, 2015 | 02:48 PM
z28mobbin's Avatar
@shoebox I'll look into that and make sure it's the right one. It seemed to fit it but just to be sure I'll look again tonight when I open it up. Thanks.
Old Aug 21, 2015 | 02:57 PM
z28mobbin's Avatar
So the oil pressure sensor is supposed to go into this hole correct?
Old Aug 22, 2015 | 12:11 PM
z28mobbin's Avatar
And the winner is...... shoeboxvette lol.
What a stupid mistake lol but i appreciate the help and ideas and all. Thanks everyone.
Old Aug 22, 2015 | 02:17 PM
KCS's Avatar
KCS
Moderator
Good to see you found the problem.
Old Aug 22, 2015 | 06:19 PM
3.8TransAM's Avatar
I'll admit I laughed when I saw the pic.
I'll also admit that myself included there isn't a person on the boards who hasn't done something just as dumb.
It's nice when folks post it so others can see what happened. Sometimes obvious is only obvious after it kicks u in the nuts.
