Question on a stripped bolt
Old Aug 22, 2015 | 07:20 PM
danieljaimet's Avatar
Default Question on a stripped bolt
While installing my new cam I was trying to torque the cam retainer plate to spec and at 20 foot lbs the bottom plate retainer bolt is somewhat stripped. Not enough to wiggle or back out but at 20 ft lbs it spins. What is a good fix for this?
Old Aug 22, 2015 | 11:32 PM
conan's Avatar
Re-tap bigger threads and install a Helicoil.
Old Aug 23, 2015 | 03:36 AM
joecar's Avatar
There is a Time-Sert for that bolt hole, see hole # 15 in attached doc (printed from GM Service Manual).
File Type: pdf
File Type: pdf
Old Aug 23, 2015 | 07:42 AM
vettenuts's Avatar
Is this the original cam plate or the new replacement with the countersunk holes? The new one uses different screws and a different torque value than the original flat design.
