bolt ons ls1 210,000 miles. ported tsp oil pump good idea?
Found a good deal on a brand new tsp ported ls6 oil pump. I am debating weather this would be a good idea to get for when chain comes due. But worried about my motor blowing all my oil out the pan
An ls6 pump is not a high volume pump. Only the DoD and melling HV are. (I'm sure there are others) The difference is that the gearotor is wider. A ported pump is certainly better than a stock one but you might as well go with a melling.
I highly doubt you'll suck the pan dry. I've been running a HV Melling for a while and never had an issue.
TSP certainly charges a bit for a ported and shimmed ls6 pump new. It's probably about the same as a melling high pressure pump. If it is indeed brand new $80 is a pretty good price. I'd ask to see the gearotor unassembled. If it's new, buy away.
