Cam clearance for LQ4
Old Aug 31, 2015 | 03:43 PM
LSLoveday23's Avatar
Default Cam clearance for LQ4
Quick question, will this cam (Duration at .050 - 230/234
Lift with 1.7 - .612/.595) fit into my LQ4 w/ 243 heads with no clearance issues?
Or will i have to fly cut or anything?
Thanks in advance for the help, youngster willing to learn
Old Aug 31, 2015 | 09:42 PM
lsxdick's Avatar
It most likely will fit without fly cutting. However, other things like head gaskets come into play. To be 100% sure you should measure your PTV clearance.
Old Aug 31, 2015 | 09:46 PM
speedtigger's Avatar
Old School Heavy
In order to determing clearance, you will need to know the intake centerline and lobe seperation angle. Do you have the full cam specs or the cam spec sheet?
Old Sep 2, 2015 | 09:21 PM
Thanks guys, the Lobe separation is 113, and the intake center line is 109
Old Sep 3, 2015 | 07:37 AM
Old School Heavy
As long as the heads have not been milled more than .020", I would run that cam with confidence if installed correctly.
Old Sep 3, 2015 | 11:59 AM
What if they have been milled exactly .020?
Old Sep 3, 2015 | 04:58 PM
Old School Heavy
I would expect you will be okay milling .020" with those head on an LQ4, but that does not mean you should not check before you run it. Checking is always the way to go.
Old Sep 5, 2015 | 11:26 AM
Yes sir! Definitely gonna make sure it'll work after its all together, thank you!!!
