Crank Thread cleaner?
Old Sep 6, 2015 | 04:03 PM
wayland1985's Avatar
Default Crank Thread cleaner?
Does anybody know of a good crank thread cleaning tool? I didn't see anything on ARP's site.
My crank threads are a bit mucked up, and I'd like to clean them before I go to town installing the balancer...
Old Sep 6, 2015 | 04:15 PM
KCS's Avatar
KCS
Moderator
You can cut a groove up the threads of an old bolt and use it as a thread chase. I do that all the time and it works really well and it's cheap lol
Old Sep 6, 2015 | 04:42 PM
I was considering that, since I'll have a spare GM bolt laying around...
But I was hoping somebody made a more official version. After cleaning my head-bolt threads with the ARP chaser, it became very clear cutting a groove doesn't clean everything.
Old Sep 6, 2015 | 09:21 PM
S10xGN's Avatar
ARP's 11mm head bolt cleaning tap is $45, I'd hate to see what their 16mm tap would go for. Of course, that may be a more common size that can be had at a supply store...
Old Sep 6, 2015 | 10:25 PM
I think I found an Irwin tap that might do the trick... But I'll need to find an extension
Old Sep 6, 2015 | 10:40 PM
slogo's Avatar
Summit has one
http://www.summitracing.com/parts/ar...FVc7gQod7HsAvw
Old Sep 7, 2015 | 01:23 AM
joecar's Avatar
What is the Irwin part number...?
( is it a thread cleaner/chaser and not a cutting tap...? )
Old Sep 7, 2015 | 01:24 AM
joecar's Avatar
Originally Posted by slogo
That (ARP 912-0011) is the thread cleaner for the head bolt holes, not the crank balancer/damper bolt hole.
Old Sep 7, 2015 | 07:12 AM
It is actually a tap. SKU: 1756ZR
Old Sep 7, 2015 | 08:12 AM
vettenuts's Avatar
I would be concerned with running a tap because that thread class in the crank is not known and a different class tap would take out material.
Old Sep 7, 2015 | 07:30 PM
Yea, I did a little more research into taps vs chasers and that was the general consensus.
I emailed ARP on the off chance they have something that'll suit my needs.... Otherwise I'll just go with the custom cut bolt.
Old Sep 8, 2015 | 06:15 AM
vettenuts's Avatar
Have you tried McMaster-Carr or Grainger?
Old Sep 8, 2015 | 08:49 AM
I didn't see anything after a quick search on grainger, but I haven't tried the other company yet
