ms3 cam
Old Sep 13, 2015 | 05:01 PM
02sunsetorangeZ's Avatar
Default ms3 cam
I'm sure this has been beat to death but I'm not finding any luck of what i need. don't have enough money for the build i want to do, it'll take awhile. My car is an 02 with full bolt ons. thinking of an ms3 cam. I would do springs, push rods and of course gaskets and new head bolts. My question is, ls2 timing chain and thats all i need? no new sprockets? chain only? also should i do ls6 high pressure or volume oil pump or would i even need oil pump for a cam only, i just hit 80k miles. Fuel injectors or would stock be fine? Excuse my questions if they have been asked many times, thanks advance.
Old Sep 13, 2015 | 08:38 PM
TXZ28LS1's Avatar
What are your goals for the car? Is it an all out drag car? A daily driven car? Or are you trying to make a certain hp?
Old Sep 14, 2015 | 05:59 AM
farmington's Avatar
At 80k an LS6 oil pump would be a good idea. I ended up needing 36# injectors. some people manage to get by with stockers. you will need a new balancer bolt also, they're single use.
Old Sep 14, 2015 | 09:15 AM
Well honestly just looking to be close to 400whp I wanna do a boost build later down the road. Just want more power and a lope for now. So ls6 oil pump, high pressure or high volume? Thanks again guys
