Engine Restore
The Restore may have loosened some gunk in the engine that's now stuck in the oil filter-as it should be.
I would suggest you now do an oil & filter change. Use a good filter like a Mobil1, K&N or Wix. No Fram or store brand.
140 MPH, eh? Tell us more about this vehicle.
https://ls1tech.com/forums/generatio...g-threads.html
WOT after adding that crap to your engine can literally destroy it....depending on how much you diluted your already old oil.
Do TWO oil changes. Drain it all out.....then fill it with 4 qrts of any cheap oil. Run it for 5 minutes so it warms up a little. Drain that oil. Then change the oil filter and put new oil in.
Go see if your oil pressure is back to normal. Hopefully by going WOT with thinned out oil from the Engine Restore crap....you didn't damage your main bearings or any other bearings.
Anything that says..."Pour this in your engine and it'll be like brand new" means its total garbage and to never ever buy it.
If you want to clean your crankcase....ONLY idle after pouring any cleaning chemicals into the crankcase.
