help!!! 408 stroker
Old Sep 21, 2015 | 01:00 PM
heavychevy123's Avatar
Default help!!! 408 stroker
Hey guys I'm need g some help planning out my 408 please criticize. This motor will be going in a 2003 3/4 ton truck. I am wanting around 500 or 600 rwhp NA. I will be using L92 heads more than likely ported, I am not sure on a cam will I need new fuel rails or throttle body? Any suggestions will be help full is this possible and around what will it cost do do all this
Old Sep 21, 2015 | 05:42 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
600 RWHP from 408" NA in a truck!? HUGELY EXPENSIVE &
not practical. You would need at least 11.5 - 12.0:1 Compression
At least 6500-7000+RPM for peak HP Probably LLSR CAM and
A whole lot of other EXPENSIVE Details. 500 RWHP much more practical and daily drivable If that matters still not cheap. I would run the MMS 235s with a Ported FAST Truck manifold. Could reach low perhaps mid 500s with medium
Sized cam.
L92s need porting for sure and the just the right cam
Easier to mess up because once you port the L92 Heads you
Have ~280CC port sizes vs 235 for the same or less intake flow
And MUCH LESS exhaust flow so you need big split 8-12* minimum
Vs 4-6* with MMS235s as an example.
Do a search in the 408 results section, Study Well.
Good Luck
Old Sep 21, 2015 | 06:07 PM
ahritchie's Avatar
I would go turbo for that power level and being a heavy truck.
Old Sep 21, 2015 | 06:44 PM
1989GTA's Avatar
Dittos to that.
Old Sep 21, 2015 | 09:50 PM
Sized cam.
Good Luck
600 was kinda random I admit that lol I was just curious if it was possible. Thanks for the tip
Old Sep 21, 2015 | 09:53 PM
I though about a turbo but for some unknown reason I want a NA motor. Tho I do have a lq9 I am thinking of putting a turbo on
Old Sep 21, 2015 | 09:54 PM
After the motor is complete there is no way the stock computer would read the changes ... right ? That being said how do I get the computer reprogrammed for the mods
Old Sep 22, 2015 | 03:12 AM
Burken01's Avatar
You need to contact a tuner/shop vendor and bring the car in for a dyno tune..
Either tow it there or see if you can get a break in tune flash to get the car up and running so you can slowly drive it to them..
