Valves: To lap or not to lap?
Old Sep 22, 2015 | 02:13 PM
SaberD's Avatar
Default Valves: To lap or not to lap?
That is the question.... In the middle of a head gasket job. Installing new springs and seals also. Just wondering if I should lap the valves while I'm at it. The motor has been relatively stock its whole life with 135k miles.
How much will lapping the valves affect pushrod length? Is it negligible?
Hand lapping tool or drill?
Exhaust
Intake
Any thoughts?
-99 c5 LS1
Old Sep 22, 2015 | 02:30 PM
KCS's Avatar
KCS
Moderator
I wouldn't lap in the valves to bandaid a sealing problem.
I usually just lap the valves to check the concentricity and contact area of the seat angle. It won't remove any noticeable amount of material if done correctly, and that does not include using a drill. You should use the handle with the suction cups to hand lap the valves.
Old Sep 22, 2015 | 02:55 PM
01ssreda4's Avatar
I agree with above except im impatient and use a drill. Takes about 10 secs per stem and gets the faces nice and pretty. Generally if I'm installing a used head with no issues I will do this just to check the sealing surfaces and to slightly renew them. With compound, you get a very good look at how the two parts are mating, and therefore how well they will seal.
Old Sep 22, 2015 | 03:13 PM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
Lap 'em! I have our 160K mile LS2 apart right now and will be doing the same.
Old Sep 22, 2015 | 04:01 PM
SaberD's Avatar
What grit of lapping compound would you guys recommend just to refresh the seal?
I don't have any sealing problems that I'm aware of , but I want to prolong the life of the seal as the engine has a lot of miles.
Old Sep 23, 2015 | 01:38 PM
JRENIGAR's Avatar
A good 3 angle valve job while they were off isnt a bad idea either. It should actually help with airflow also.
Old Sep 23, 2015 | 09:19 PM
01ssreda4's Avatar
I use the coarse. I spin and bounce them softly on and off the seat. After 10 or 15 seconds the sealing surfaces are purty.
Old Sep 24, 2015 | 02:40 AM
Exidous's Avatar
I'd consider soaking the valves in some lacquer thinner and use a bronze bristle brush. Most of the crap will come off and you may not even need to lap. Try to soak the seats as well.
Without a hot tank, lacquer thinner is the next best thing. I was really surprised how much crap came off.
Old Sep 26, 2015 | 04:34 PM
ChucksZ06's Avatar
Definitely lightly lap them. It cleans them up and you can check the contact easily.
