installing viton valve seals
Old Sep 30, 2015 | 03:44 PM
LSx '85 C10's Avatar
Default installing viton valve seals
hi i just installed a new set of dual springs with viton valve stem seals and i didnt tap them on with a socket, just slide them on with my fingers, I installed them about two weeks ago and I have noticed some smoke at WOT should I take the springs off and tap them on or just leave them?
Old Sep 30, 2015 | 03:54 PM
TurboBuick6's Avatar
They need to be tapped on. A socket and dead blow work great.
Old Sep 30, 2015 | 08:51 PM
01ssreda4's Avatar
Yes they must be tapped.
Old Oct 1, 2015 | 08:50 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
I would definitely go back and check the valve seals, more than likely they aren't going to be reusable so pick up another set before you tear everything apart. I have always tapped them on with a valve seal tool I made but you can also use an appropriate sized socket.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Oct 2, 2015 | 10:46 AM
VandykeT/A's Avatar
12mm socket and a couple light taps.
