Timing chain set question
Old Oct 4, 2015 | 12:46 PM
Don Vito's Avatar
Default Timing chain set question
Hi All,
I ordered a new timing chain set for my gen III 5.3 I received a set for a later Gen motor with the sensor bump on the cam gear. I don't think there is any issue with using it on my Gen III motor but thought I would ask to make sure.
Thanks
Old Oct 4, 2015 | 03:59 PM
svede1212's Avatar
Should work fine.
Old Oct 7, 2015 | 11:27 AM
MYSTIC-1SC's Avatar
It should work no problem.
Old Oct 10, 2015 | 03:55 PM
chrisfrost's Avatar
depends on the year "later gen" motor because they went to a single bolt gear to cam set up so be aware of that . I don't remember what year gen 4's did that but if You search it You'll find the info or just look at you're new timing gear . gen3's use 3 bolts holding the cam gear to the cam
