Who has the quickest turnaround on custom grind camshafts?
I need a new camshaft to replace the one that was either damaged or failed in my LS1 (cracks in a lobe). I'm running out of time to get this car finished before winter. I've spent the last 6 months rebuilding and reconditioning the entire car and this cam is the last hold up.
In everyone's experience, who has had the quickest turnaround for specing out and grinding out a new camshaft with good results? Anyone grinding non comp cams cores with a quick turnaround? I can handle a couple weeks but a month or more is out of the question (I've read that it could take that long from some vendors). I don't even care about cost at this point. I just want my car finished.
LS1Tech Premium Sponsor
Give us a call. We are grinding cams in house with Callies Cores and it can be done in 1-2 days.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
