Torquer v4 or MS4 need advice
98 z28 auto with rpm built transmission with 3600 stall.
Has 3.42 rear end from m6 car.
Full exhaust with egr delete and smog delete.
Has ls6 intake manifold with ported throttle body.
tuned by frost.
Car does 13.4 at 6000 elevation.
With my cam upgrade i will be installing a fast 102 with throttle body bigger injectors
Spings and pushrods
Ls7 lifters
Ported 243 heads.
Oil pump
Rocker truion upgrade.
New fuel pump.
Cars is used as dd on the weekend and is beat on at least one night a week. Mostly highway pulls but i do take it to the track once a month. I built my suspension around a street strip combo With ajustable coils up front and bmr Springs out back. Hooks up good.
Tuning after the cam install would be done via hp tuners data log then sending it to texas speed.
Leaning more towrds the torquer v4 but like the topend from the ms4. Whats your opinions.
If you can get your car in the 2900-3100lbs ran I'd go with it but there are better options out there. At least TSP now offers this cam with lobes that are more street friendly.
I say the V4 is the better option for you out of the two
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
