Upgrade to LS3 or build LS1?
I've just started driving my 73 240Z with a LS1 swap. I used a 98 Trans am donor Engine, Trans, wiring and computer. Before I put it in a replaced the cam, valve springs with Z06 parts and did a LS6 intake. The car is somewhat quick. Weight is around 2400#. Using the car on the street and driving schools. So the issue is do I start collecting parts to upgrade the LS1 OR Jump up to the next generation stuff? I always need a project.
Are most people happy with there LS1 or LS2's after they do heads and cams... Or wish they just spent that money on a LS3 build.
What are your end goals? If you are wanting a 500whp NA build then go with the LS3.
Maybe I should find a good set of heads that would work nice on both the LS1 and a Ls2 bottom. That way I can use them with the bigger motor down the road. If I need more power.
My mild H/C/I FRC trapped mid 120's on street tires. Yours is much lighter...will go 130+.
I just had a 226/230 114 cam,AI 799 heads and a fast 90. Going to an LS3 gives you the advantage of having more head options due to the bigger bore, but in the end a maxed out ls3 is going to make only 40-50 more hp over a maxed out ls1. If your short block is in good running order, I say stick with that.
