HP vs TQ Theory
So what, exactly, is the estimated sum net difference we are talking about here in terms of discernible variance in VE, or power production, (ie, on V8R's engine being used in the model) between an engine that would be equipped with a 180, or even a 360, crossover header vs not?
More over, the variance mentioned between the high VE table vs low VE table that gets "averaged"?
( notice the terminology I used: VE table vs VE... i.e. "table" implying it is the calibration table, and lack of "table" implying it is the actual physical VE )
As to my cam timing, 227/236 - 112+3
Event......0.006"............0.050"
EVO........79.5 BBDC......53 BBDC
EVC........29.5 ATDC.......3 ATDC
EVD........289 Degrees....236 Degrees
IVO.........31 BTDC..........4.5 BTDC
IVC..........69 ABDC.........42.5 ABDC
IVD.........280 Degrees.....227 Degrees
Side comment, not pertinent to discussion - I have really enjoyed this cam. Drives well, enough lope to get attention, and unless I try to coast at 15mph in third, it's fine. Knowing more now than I did, if I were to re-spec the cam, I would hold the exhaust duration constant, and open up the intake a bit more. Maybe after the dual exhaust is in. At the time, I figured my set up was very intake biased, so I wanted the added exhaust duration to compensate for the comparatively aneamic exhaust flow.
One dyno of a friends pro-stock circle track motor the difference between a 180 cross over header vs regular was 8-9lb/ft & about 7hp on a 475HP SBC.
So in the range of about .7lb/min of theoretical VE variance. Entirely impossible to know in this circumstance.
Have any WOT EGT's?
Also, & I know this sounds odd, cranking compression & maybe a leak down average number?
Results/data
Fuel economy on the highway with OEM camshaft vs aftermarket camshaft is identical, if not better with the aftermarket cam. It cruises with the same injector duty and nets 26-29mpg depending how I drive on the highway, with 30 max.
The upgrade camshaft reduced idle quality and added 50% more injector duty to the idle speed (from 1% to 1.5% injector duty) and more airflow was necessary at the IACV to hold a reasonable 850~rpm idle, although the engine sounds most happy between 880-920rpm. The cam is too large for the turbo (on purpose for the lope) the trade-off being the reduced economy at idle (but not highway or normal driving).
highway injector duty cycle at 60mph is exactly 6%. Disconnecting the turbine (deactivating the flapper so it hangs open) raises that to 6.5%. This is a great example of how "pumping losses" or if you want "parasitic losses" due to the engine having to work harder for it's air results with less fuel economy. Cruise vacuum also drops but the engine uses a MAF and I do not have a boost gauge accurate enough for the job (the boost controller gives me a peak boost number but little else). Is it so obvious that a turbocharger would/should improve BSFC for a highway cruise? And if that doesn't mess you up yet, heres a next observation, I have ten or so feet of intercooler plumbing with 2.5" and 3" plumbing, along with a 3"x48"x12" intercooler (tons of volume to move) and I suspect this is the major reason why the turbocharger seems to be "helping my fuel economy" (because without one, the engine has to draw air through all that pipe, it cant be easy) So would the engine achieve a higher economy without all the extra plumbing, how much of a difference would it make. Can we calculate how much energy is lost pulling X CFM through pipe with a length/cross section Y?
