Replacing one piston.
Old Oct 25, 2015 | 10:08 PM
Mxjustin22's Avatar
Default Replacing one piston.
Replacing one bent rod in ls1 out of a 98 Camaro. Engine shop has a 6.0 rod said was the Same he could use and when trying to change it over it cracked so now I'm wondering if I should go with piston from gm for $104 or go with one from like jegs for $20. Just need oem replacement I belive. Any comments about the build would be apreciated.
