Piston ring gap and oil ring tension
Old Oct 28, 2015 | 05:44 AM
mngoos's Avatar
Default Piston ring gap and oil ring tension
OK so the rings I ordered are too big my bore is 3.900 I ordered 3.905 bore rings
Will I be fine to file them down ?
If yes what should my tension be for the oil control ring ?
Ls1 with vrx4 cam and 243 heads and flat top sealed power pistons just a little info on the engine
Old Oct 28, 2015 | 08:26 AM
KCS's Avatar
KCS
Moderator
Usually file fit rings are about .005" over sized, so you should be good there.
As far as tension, that's something the manufacturer would know.
