Comp cam?
Old Oct 23, 2015 | 08:23 PM
cosmo04's Avatar
Default Comp cam?
I just recently got a cam from a friend. And it has these numbers on it. Can anyone tell me what they mean? It's not a part number
Old Oct 23, 2015 | 10:03 PM
SilverSS's Avatar
Looks like a Comp LSL 243/251 .624 .624 113lsa
http://www.compcams.com/Technical/Ca...obeCatalog.pdf
Old Oct 23, 2015 | 10:08 PM
cosmo04's Avatar
Is it a custom cam?
Old Oct 23, 2015 | 10:17 PM
SilverSS's Avatar
I'd say it is. Comp 54-462-11 but on a 113lsa
Old Oct 23, 2015 | 10:39 PM
cosmo04's Avatar
Work with stock pistons?
Old Oct 23, 2015 | 11:37 PM
SilverSS's Avatar
i don't think it would. maybe one of the cam experts could tell as i'm not a big cam runner. that's a big cam for stock cubes and is suited for a stroker.
Old Oct 23, 2015 | 11:52 PM
cosmo04's Avatar
A ms4 is a way bigger cam, and it's a 111lsa. It supposedly clears stock pistons.
Old Oct 24, 2015 | 08:34 AM
HCI2000SS's Avatar
If this cam truly has a 243/251 duration on a 113 LSA, then it's a lot bigger than the MS4, and will not clear on a stock LS1
Old Oct 24, 2015 | 10:13 AM
cosmo04's Avatar
Oddly this is for that cam
Old Oct 27, 2015 | 07:45 PM
cosmo04's Avatar
So, I got the cam in
Old Oct 27, 2015 | 07:49 PM
96capricemgr's Avatar
In a stock LS1?
Old Oct 27, 2015 | 07:50 PM
cosmo04's Avatar
Yep. I would post a video but don't know how
Old Oct 28, 2015 | 07:30 AM
gagliano7's Avatar
How does it run?
Old Oct 28, 2015 | 07:42 AM
HCI2000SS's Avatar
How did you get it to fit?
Old Oct 28, 2015 | 07:50 AM
cosmo04's Avatar
I didn't do anything actually. Installed the springs. Put the cam in and before I put everything back together. I installed the push rods and rockers, spun the motor a few times and didn't feel anything. So i took the chance and crank the motor over a couple times and didn't hear anything funny. So I hook up the plugs and it started. Needs a tune but sounds really good. This is a picture of a sheet that cam with the cam
Old Oct 28, 2015 | 08:01 AM
HCI2000SS's Avatar
Yeah I saw that cam card, but with that much duration with a 110 ICL I'm surprised it fit
Old Oct 28, 2015 | 08:05 AM
cosmo04's Avatar
It's actually a 113 which is nice
Old Oct 28, 2015 | 08:07 AM
HCI2000SS's Avatar
Right but the intake centerline is 110 which reduces clearance
Old Oct 28, 2015 | 08:11 AM
cosmo04's Avatar
Ohh I see what you mean. Well, hopefully the cam works good and makes noticeable power difference from before
Old Oct 28, 2015 | 08:13 AM
HCI2000SS's Avatar
If it's clearing then I guess all is good, I'm just surprised. Probably a bit of a dog down low, but should make some big top end power
