New Build, No Oil Pressure
Figured I'd come here for help. I did not build it, had a local shop do it. Assembly lube was used as well. I have no doubts its a bearing problem, same guy built a buddies engine and fired right up with no issues.
New build, LS2, K1 Crank, Eagle Rods. Wiseco Pistons, High Volume Oil Pump
CB663HN - Rod Bearings
MS2199H - Main Bearings
Turned it over for first time today, ran for 5-10 seconds and died due to fueling issue, no oil pressure.
Repeat 2 more times, 5-10 seconds each, same results. I poured oil into the filter to help prime it before hand, not a whole quart. After trying to crank it, I loosened the filter and oil gushed out. I'm using a sandwich plate and removed a fitting for mechanical gauge and same results, oil poured out. Checked drivers side head, bone dry.
Will verify with mechanical gauge tomorrow. Pulled Fuel Pump, Injector and Coil fuses, to turn it over... Correct me if I'm wrong in doing this please.
I'm at a loss right now.
