6.0 Compression and pump gas
I have a lead on a set of 799 heads. My concern is with my set up can I still run on pump gas. The engine will go into my 95 firebird convertible which is currently a 3.4 5 speed dog. This will be a fair weather driver. No track time. I am looking for a fun car I can be proud of. I drive a minivan most days. Here is what the engine would look like with the 799's.
Lq4 block
Lq9 Pistons
Ls6 Intake, with ported TB
I will need a different cam because the lq4 cam is for a truck. Here are the specs of the cam I was looking at.
Tick Performance ls2 street heat stage 1 229/232 | .619”/.600” | LSA113+3
From what I understand the specs of this build would be essently the same as the ls2
From what I read the compression would be close to 11.1. If I use the 799 heads instead of the 317 would my compression be too high for pump gas.
Also, I read that high compression might lead to "detonation". What does that mean?
On a LS motor, if you are around 11:1 compression, you should be fine. Just run premium gas. Lots of us run 11.5:1, and that just requires knowing your cam specs very well
Lq4 block
Lq9 Pistons
Lq4 block
Lq9 Pistons
Disregard my mph in my sig as it's misleading due to a headwind, it should have been about 111-112 but that's how weather goes on track days.
226/232 .612/.595 112+2
This camshaft would be ground with my IP/XP lobe combination on either a Cam Motion 5150 or 8620 cam core. I do recommend the 8620 cam core as well.
This cam would be very fun to drive and would have a powerband of roughly 2200-6600 RPM. Good power at low engine speeds, strong mid-range and enough top end pull for those long stretches of open highway we often encounter out in "Mexico" ....
