cam idea?
Old Dec 14, 2015 | 08:38 PM
jseal_57's Avatar
Default cam idea?
need a cam for my truck. its a 1970 C10 about 4000lbs and it has a 4l60e with 2500-2800 stall and 4.10 gears. motor is a 5.3L with 243 heads milled down to stock combustion chamber size and truck intake manifold. mostly a street truck so would like lots of torque and nice sound.
Old Dec 15, 2015 | 08:43 PM
Deeohgie69's Avatar
I'd give Texas Speed or any of the sponsors on here a call. I've talked to 4 or 5 of them and they are all happy to help you and will definitely guide you in the right direction for your needs/goals.
Good luck!
Old Dec 15, 2015 | 10:03 PM
jseal_57's Avatar
thinking of going with this cam
http://www.texas-speed.com/p-5002-te...-camshaft.aspx
Old Dec 17, 2015 | 10:24 PM
alowerlevel's Avatar
Originally Posted by jseal_57
Might want to have a look at BTRs truck cams too http://www.briantooleyracing.com/truck-cams.html
Old Dec 18, 2015 | 08:55 AM
thunderstruck507's Avatar
http://store.cammotion.com/little-ch...otrod-camshaft
That sounds like it fits your bill perfectly.
Old Dec 23, 2015 | 12:35 PM
Martin Smallwood's Avatar
This is what I would recommend:
216/224 .586/.569 114+2
This cam can be used with a PAC 1218 beehive valve spring which could still use the factory retainers to save a little cash. It will need hardened chromoly push rods at the appropriate length, and I'd also recommend a trunion upgrade, Melling HP oil pump and a IWIS timing chain. You'll need gaskets as well to swap the cam and I like to use ARP cam bolts and ARP balancer bolts in my cam packages.
I have several packages that would supply all the required items you will need for the cam package and swap.
I could also knock more lift off the cam so it could be used with LS6 valve springs. I do this a lot for customers that drive their vehicles 10-20k miles a year. Using the lower pressure LS6 spring allows the spring to last longer along with milder ramps on the camshaft also lending to increased spring longevity.
If I can help with anything else please let me know!
Old Dec 23, 2015 | 12:47 PM
spawne32's Avatar
no website yet martin? need help with that?
Old Dec 23, 2015 | 09:04 PM
jseal_57's Avatar
ok thanks.
