Valve Spring Opinion
Btw.. I'll let you in on a little secret, check out the springs that AFR sells on their heads that are rated for high lift cams, guess who's they are... Yep.. Patriot GOLD dual springs on the new AFR heads.
I was told that the cause is too low of seat pressure on the springs. Options I was given was to shim my current springs or try the PP springs. Trending Topics
Give me a call, we have the springs instock & they'll work with your existing Crane retainers
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
10k miles on them.
10k miles on them.
