How To: Wipe Pattern for Roller Rocker and Pushrod Length
I only mention as the 0.062" mentioned in the OP would be 1.575mm, so possibly the shims are slightly different now.
My wipe pattern with 1 shim, they're a little towards the exhaust and a maybe a bit wide (I'll be running a little over 0.650" lift so perhaps they're not excessively wide?)
To sanity check I put another shim on just to confirm the sweep moved more to the exhaust side and it did, although tightened up a touch
Just wanted to say thanks from across the pond for the thread, was really helpful
Will be referring back for pushrod length and making up a little measuring jig once the 12" calipers arrive.
Mine's a 402 with a Mamo top end, hand finished MMS235s, the 1.8 YTs, Tony specced the cam etc. and just put a deposit on an RPS BC2.
Mamo is a dangerous man to talk to on the phone LOL
Previous image above was with the factory YT 1.5mm shims (apologies for all the metric, ~0.060" shims), so I got a bunch of 0.25mm (~0.010") shims and set about trying to improve it. It was a bit to the exhaust side, so I jumped down to 1mm of shim (0.040") and got this:
Still a bit to the exhaust and perhaps a little wide. Jumped down to 0.5mm (0.020") and got this:
Comfortably around the centre point, but really wide and I felt I'd probably gone bit too far here, so went to 0.75mm (0.030") of shims and got this
I'd perhaps put a bit too much blue on there which had stacked up either side of the wipe, but it looks good and central and fairly tight. I attempted to roughly measure it and it looks about 1.5mm (0.060"). I'm running a little over 0.650" of lift, so is that a fairly reasonable pattern? I couldn't get a decent viewing angle to really get a feel for where on the tip the roller is at peak lift, I'll probably re-blue it tonight and try again just to verify it wasn't a fluke. I mic'd the shims and they came to about 0.8mm in reality, I imagine tolerances stacking up (as it's 3 x 0.25mm washers).
Appreciate any thoughts / critiques
They fit perfectly inside the recess in the rocker shaft, and they're available off the shelf in all sorts of thicknesses (shims in the right hand rocker)
