Checking PTV clearance head fully torqued?
Old Dec 22, 2015 | 09:10 PM
starbucks's Avatar
Default Checking PTV clearance head fully torqued?
Hey guys I got a pretty simple question I'm getting ready to check Piston to valve clearance and have a question. Do all of the head studs need to be torqued down in three stages for this or can I just use the four around the cylinder that I'm checking or could this possibly warp the head.?
Old Dec 22, 2015 | 09:57 PM
gsxrdan2's Avatar
I always just torque it all the way with the old gasket in place to measure.
Old Dec 22, 2015 | 10:06 PM
S10xGN's Avatar
I used an old gasket and about 20# on the 4 bolts on the cylinder to be checked. Went back after new head gaskets and full torque and saw no change...
Old Dec 22, 2015 | 10:56 PM
starbucks's Avatar
I plan on using a a generic Felpro head gasket that came in the gasket kit for the rebuild. Since it is a new gasket that I plan on using to check for piston to valve clearance should I maybe torque all of them down? For the record this gasket is .048 thick and I plan on using an ls9 which is .051 thick.
Old Dec 23, 2015 | 07:20 AM
vettenuts's Avatar
Use the old gasket, 0.003" is probably within the margin of error especially if using clay. What I did, since I was going to a 0.040" Cometic, was strip one layer off the removed GM gaskets to get the correct thickness.
Old Dec 23, 2015 | 10:35 AM
Jontall's Avatar
Just completely torque the head in sequence to avoid any warping.
Old Dec 23, 2015 | 11:24 AM
01ssreda4's Avatar
I agree. Id torque like normal just to avoid any possible headaches, or at least torque evenly across the head if using an old gasket.
Old Dec 23, 2015 | 01:31 PM
Old Geezer's Avatar
Head on the deck face, snugged down. Make measurements, add in compressed thickness.
Old Dec 23, 2015 | 06:56 PM
01ssreda4's Avatar
Cant spin the motor over like that due to the piston coming out of the top of the block.
Old Dec 23, 2015 | 07:20 PM
SHovV's Avatar
I torqued my head all the way down in the 3 step sequence with the .040 new cometics I was using. That's the right way imo
Old Dec 25, 2015 | 09:12 AM
Old Geezer's Avatar
Red face Whoops!
Back to thinking of sbc's
