lets talk rocker arms
Old Jan 2, 2016 | 02:12 PM
k_garretson23's Avatar
Default lets talk rocker arms
Looking for quality roller rocker arms for my build. I have mamo motorsport 235 heads with bronze guides so a stock arm with the bearing upgrade is not an option. Would like to stick with a 1.7 ratio. Have a pretty aggressive custom cam being speced out by tony mamo. I dont mind spending money but if the same performance can be achieved without dumping 1200$ on rocker arms I am not opposed to saving some money.
Old Jan 2, 2016 | 07:05 PM
tadams72's Avatar
Tony didn't suggest the Yella Terra rockers?
Old Jan 2, 2016 | 08:41 PM
i didnt speak to him about rockers just heads/cam set up
Old Jan 2, 2016 | 08:56 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Tony recommends Yella Terras nearly exclusively for all
His HR Head/Cam combos.
Tell us more about your build and goals.
Old Jan 2, 2016 | 09:00 PM
Black02SLP's Avatar
5_litre_eater has a thread on hear if you haven't seen already. He's using the Yella Terra rockers. I see your point on wanting to save a few buck's. But saving a few bucks might be more expensive down the road. JMO.
Old Jan 2, 2016 | 10:39 PM
tadams72's Avatar
Lots of us running Yella Terra's. I've got them on my 427 build. Tony will hook you up with what is necessary and they are about half the cost of a shaft system.
Old Jan 2, 2016 | 11:56 PM
Darth_V8r's Avatar
Moderator
I second going through Tony. There is a 10mm rocker bolt option that I believe is exclusive to him. Since you're getting his heads anyway...
Old Jan 3, 2016 | 12:16 AM
Actually Darth you are thirding or fourthing LOL!
Old Jan 3, 2016 | 09:59 AM
its a built 370 iron block, wiseco pistons, callies rods, 10.8:1 compresion, stock crank, arp head/mainstuds, mms 235 nfi heads, hollow valves, custom cam by tony, vic jr intake, accufab throttle body nirtous outlet stinger kit. shooting for 500whp on motor give or take 700+ on the bottle.
Ive heard some stories about yella terras, friend of mine also personally had one break and almost destroy his motor.
Old Jan 3, 2016 | 10:15 AM
KCS's Avatar
KCS
Moderator
It might not be exactly what you're looking for, but Comp makes a nice little steel rocker arm for the LS engines. They're a little heavier than an aluminum rocker and they come in 1.8:1, but they are stiffer and fatigue isn't an issue like with aluminum. You can get them in a stud mount too so you don't have to dick around with shims or super accurate pushrod measurements to set up your valvetrain geometry.
I like them so I got the bolt on set, it was only like $345 shipped from one of our sponsors. They're going on a set of TFS heads with a .700" lift cam.
Old Jan 3, 2016 | 11:41 AM
tadams72's Avatar
Yella Terra is on the third revision for the LS Rocker Arms. I don't believe you will find anyone who has broken one recently unless it is an older style. Talk to Tony and he can set your mind at ease.
Old Jan 3, 2016 | 03:57 PM
BlackDuk98's Avatar
I am surprised that Tony didn't mention his 10mm ones. I am running those and they are quality pieces. If he still has your heads and you go with those, have him drill and tap them for the 10mm bolts before he ships them out. A lot easier having him do them instead of being paranoid the whole time doing them yourself.
Old Jan 3, 2016 | 06:27 PM
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Kevin,
The Pro 10mm Yella Terra Ultralite is the only way to go
The stories of failures are many years old and many rocker designs ago! One of the big problems of the Internet is the rehash of old news
To be honest I dont know of a single failure of one of my 10mm units that is exclusive to Mamo Motorsports (beefier stand, hardware, etc.....does require larger bolts threads be installed in the heads).
And as BlackDuk98 just mentioned getting the machine work done on the CNC (so its perfect) while the heads are still in my possession is a no brainer.
Shoot me an email when you get a chance and we can discuss it in more detail....heads are still at AFR and it would be easy to upgrade them now with the 10mm threads etc.
Appreciate all of you that have posted in this thread already....would have been on here sooner if I wasn't trying to enjoy just a couple of days of "down time".....LOL
Happy New Year guys!
-Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
