Would you use this burnt LQ4 block?
Old Jan 7, 2016 | 10:59 AM
Ernie W's Avatar
Default Would you use this burnt LQ4 block?
I picked up this engine cheap. Its a LQ4 that was pulled from a burnt truck. We pulled the heads and found some rust in the cylinders and it was stuck. Soaked the cylinders and let them sit overnight. Easily broke loose the next morning. Rotates over easily. I have yet to pull the pan but have a few concerns.
I'm looking to have the block built to a iron 6.2L. I have a nice set of L92 rods and pistons, along with the L92 heads and a BTR LS3 cam kit. Do you think I would be wasting my time with using this block? I got a quote on having the block hot tanked and cleaned, pressure checked, torque plate bore and hone, new cam bearings installed, align hone main bores, and decked to make sure flat.
Before cleaning anything up a little.
Cleaned a little.
Melted the timing cover and oil pan.
Front cam bearing.
Old Jan 7, 2016 | 11:01 AM
Ernie W's Avatar
I'm hoping to have the stock crank in this engine polished and use it with the L92 rods and pistons. It would be going into my '99 Trans Am WS6.
Old Jan 7, 2016 | 12:02 PM
KCS's Avatar
KCS
Moderator
Did the engine turn over ok?
Old Jan 7, 2016 | 12:09 PM
Ernie W's Avatar
Yes. I had a short 1/2" ratchet with a 24mm socket on the crank pulley turning it around easily. That was after I turned it back and forth a few times to break it loose. It rotated fine several times after the crud was out of the cylinders. I didn't feel any spots where it was difficult to turn either.
Old Jan 7, 2016 | 12:14 PM
high n dry's Avatar
I'd say use it! After machining,it should b good
Old Jan 7, 2016 | 12:19 PM
KCS's Avatar
KCS
Moderator
Ditto, use it!
Old Jan 7, 2016 | 12:24 PM
Ernie W's Avatar
Good deal, Thanks guys. As silly as it sounds, I was afraid it being that hot may have affected the strength of the block. I'm going to have it checked out first before doing anything to it. Just need to finish tearing it down first.
Old Jan 7, 2016 | 03:14 PM
96capricemgr's Avatar
Having melted the oilpan I would worry about the crank, snout warping or heat treatment. Suck to have the balancer wobble on startup
Old Jan 7, 2016 | 07:47 PM
76larkman's Avatar
a guy could put flywheel and starter on it see if wobbles. Just cross starter or use push button. I used to do that with unsure carb motors to run out of car.
Old Jan 17, 2016 | 10:08 AM
Ernie W's Avatar
Just a little update to this. I pulled the pan, oil pump, and timing chain out. Everything looked good when I pulled the rods and pistons out. It has the floating pin rods so I assume it's a newer later gen III block with all long head bolts. The crank spins fine with no wobble on the crank snout. The rod mains also looked fine with no spun bearings. I'd say it's safe to assume the block is fine.
Old Jan 17, 2016 | 07:43 PM
1FastBrick's Avatar
Just had one like this and it got hot on the #1 main cap. The cap did not fit tight in the register. Since the machine shop screwed up the cap trying to get it to seat tightly in the register, they are going to bore another cap and line hone it. The crank was straight how ever some of the debris scratched the journal. It would probably be ok with a polish how ever, I think I am still going to have it cut and Nitrated.
Old Jan 17, 2016 | 09:51 PM
joecar's Avatar
My concern would be anything that would have its material structure altered by the uncontrolled heat from the engine bay fire... i.e. any thing that could lose its heat treatment and/or become brittle... I would be cautious.
$0.02
Old Jan 17, 2016 | 10:03 PM
Paul Bell's Avatar
That's MISTER MODERATOR
I think as the crank snout is completely covered by the damper, even through underneath the front cover, it's fine. The damper of course is toast. As will be the oil pump and timing chain.
What is this engine going in to?
Old Jan 17, 2016 | 10:43 PM
1FastBrick's Avatar
Oh, Another tip.
Clean and check the rods good too! Mine changed color so I found some replacements. At minimum I would change the rod bolts if the rods are ok.
I also replaced the Main cap bolts as a precaution. The fact that it melted the Aluminum Shows you that it got really hot. You also don't know for how long either.
FWIW The melting point for aluminum is 1,221°F / 660°C
Old Jan 18, 2016 | 02:16 AM
denikena's Avatar
Old Jan 18, 2016 | 04:45 PM
Ernie W's Avatar
I haven't pulled the main caps yet, but they appear to be fine and the crank spins quick and easily with no catches to it. I'm hoping just a polish on the crank will be good enough. I plan on having the main bores checked and line honed if needed.
Yea the chain and pump were black from the fire. I'm hoping to have the engine machined for a set of L92 rods and pistons. Along with a set of L92 heads with LS3 intake valves, LS3 intake manifold, and BTR LS3 stage IV cam kit. It will be going into my '99 Trans Am WS6. It currently has a stock LQ4 dressed as a LS1. I'll be putting it in my '80 Firebird with the holley mounts.
Old Jan 18, 2016 | 04:49 PM
Ernie W's Avatar
$0.02
That's what has me worried. The only thing I plan on using is the block and crank. I'm going to have the machine shop check them out to make sure they would be good to use.
Oh, Another tip.
Wow, it was pretty toasty then. I'll be using a set of L92 rods and pistons on the 6.0 crank. I also have all of the main cap bolts from the L92 block I could use. I assume they would be the same.
Old Jan 25, 2016 | 02:12 AM
1FastBrick's Avatar
The main cap bolts I am not sure on between the two engines. I just bought new's from BTR. I think it was about $100
For Rods, I went with New take outs. I also picked up a set with ARP bolts already installed, Just need to have them inspected. Mine were originally Floating pin and I stuck with it for the rebuild.
Old Jan 25, 2016 | 02:42 AM
hodberta's Avatar
