LS1 valve spring shims
Old Jan 16, 2016 | 10:03 AM
rseibenick's Avatar
Default LS1 valve spring shims
Need to get the GM part # for the stock LS1 valve spring shims or locators. The one I have is .522 ID and 1.117 OD gold color. Used on all LS base engine. Thanks.
Old Jan 18, 2016 | 09:54 AM
vettenuts's Avatar
Are you looking for the spring seat (early LS1) or an actual shim to adjust the installed height?
Old Jan 18, 2016 | 10:28 AM
Brian Tooley Racing's Avatar
If you have stock beehive springs then the newer style seals have the locator made into them and work well.
http://www.briantooleyracing.com/ls-...hat-style.html
