Headgasket thickness with stock 243s
From what I've seen, people prefer between .030 and .040 for "optimal" quench clearance. LS1 pistons pop up out about .008 usually. I'm starting to worry about PTV clearance on my setup if I use a .041 gasket and have the 243s clean up milled about .003 or so.
Some guys on here run their quench in the .020s, which is getting dangerously close. Those are usually very specific builds tho, and its not recommended for an every day, DD kind of car.
I'm also in the process of having a set of 243 ported/milled. I'm running a 228/232 112LSA cam in my LS6, and am worried about clearances. I would like to avoid flycutting at all costs.
With a .020 mill, will a .040 gasket keep me in a safe zone?
Ideally that should leave me roughly a 62cc chamber, I believe, which I will be running 93 octane pump fuel with.
With a .020 mill, its going to be close. I would only go .010.
I'm running Tick SNS 3 with 243 heads milled .010 and 2.02 & 1.6 valves and I'm at .088 of clearance on exhaust valve with a .051 head gasket.
#33
Old School Heavy
I often use this calculator when trying to project piston-to-valve and I find it to be amazingly accurate: http://www.pcmofnc.com/index.php/com...nce-calculator
#34
Thank you, that's a very handy tool.
If I'm going to be that close I'll likely stick to a .010 mill and .040 gasket. I can deal with a few less points of compression for the peace of mind it brings.
Thank you for the input!
#38
Thanks, that's much bigger than I'll be going. I bought my Z06 with the current cam already in it, and was considering a larger setup at some point but am not yet sure if I'll be going that route. I want to stay conservative clearance-wise in case I do, though.
#40
I attempted to use that calculator, but since there's no full specs of the ASA cam, I can't make it work. They only show the .050 durations, and the lift and LSA. I guess I'll just have to measure
