Need help calculating compression ratio
Old Jan 27, 2016 | 09:42 AM
carguy_24's Avatar
Default Need help calculating compression ratio
My engine is a 5.3L block that has been bored to 3.8" and has the stock 3.622" stroke. The pistons are aftermarket Wiseco flat tops with -2.2cc valve reliefs in them. I have a deck height of exactly 0.000", the pistons at TDC sit completely flush with the block. I will be using a GM MLS gasket which I believe is 0.054" compressed. Heads are 243 castings that currently are 63cc and I am considering going down to 59cc so I can get my compression ratio closer to 10.5:1 or 11:1. Any help with the calculation will be appreciated and thanks in advance. If u am leaving any measurements out let me know and I'll post them as soon as possible.
Old Jan 27, 2016 | 10:59 AM
gagliano7's Avatar
As far as i know the gm mls gaskets are .051. Stroke is 3.622.
Google ls1lt1.com compression calculator. Second thing that comes up is the site.
Old Jan 27, 2016 | 11:28 AM
MuhThugga's Avatar
http://www.csgnetwork.com/compcalc.html
Old Jan 27, 2016 | 09:24 PM
Matt Burns's Avatar
http://www.summitracing.com/expertad...ion-calculator
Old Jan 29, 2016 | 09:40 PM
carguy_24's Avatar
Thanks. I just thought the wiseco paperwork said 10.25:1CR and with my milled heads to 59cc I thought I should have more then 10.46:1CR if the stock 62cc heads would give those pistons a 10.25:1CR. Especially since I'll be using the same stock head gasket.
Old Feb 6, 2016 | 03:51 PM
carguy_24's Avatar
So I did calculate it correctly because my builder told me the same compression basically as the links you guys listed. So with my 59cc heads I'll be at 10.5:1CR so I'll be good for n/a or nitrous if I add some. Or I can throw some 317 heads on with stock chambers and be close to 9:1CR and could turbo the setup later.
