Eagle rods vs. Scat rods
Old Feb 6, 2016 | 03:25 PM
65standard's Avatar
Default Eagle rods vs. Scat rods
I building a 6.0 and I'm looking at some H-beam rods with ARP 7/16 bolts. I see Eagle and Scat both have the rods I need. Is any brand better than the other? I couldn't find Manley rods is the specs I need. Need 6.100 with .944 pin.
Old Feb 6, 2016 | 03:34 PM
machinistone's Avatar
Between those two I'll always pick Scat due to manufacturing and QC/sizing issues with Eagle almost every time.
Better would be what I've converted over to using which are Molnar Technologies rods, but I'm not sure if he makes a 6.098/6.100 rod with a stock pin diameter bushing - I'd have to ask him on Monday.
Old Feb 6, 2016 | 03:53 PM
65standard's Avatar
Im open to suggestions as long as they're h-beam rods in the stock LS2 size. Please let me know if Molnar makes them.
Old Feb 6, 2016 | 04:57 PM
xdanny510x's Avatar
Ran the eagle h rods in my 408 no problem ... until i heard loud knockin... so im pullin motor and inspecting
Old Feb 19, 2016 | 06:44 PM
65standard's Avatar
Did you find the source and cause of your knock?
Old Feb 19, 2016 | 08:04 PM
64post's Avatar
The Scat H- beam Q-lites are interesting because they come in both 6.100 and 6.125 and are so much lighter than all the competetor's at 560-570 grams compared to the 630-660 gram other H beams. Lighter revs faster every time. They're priced reasonable.
Old Feb 21, 2016 | 02:57 AM
ls1 1990 VN's Avatar
I've had zero issues with my Scat H beam 6.125 rods over the last 8yrs
Old Feb 21, 2016 | 07:03 AM
65standard's Avatar
If I run 6.125 rods the Pistons will pop out .021".
This with a 6.0 flat tops and 61cc heads, my compression would be to the moon.
Is there any issues with a +0.021 deck height?
Old Feb 21, 2016 | 07:13 AM
redtan's Avatar
Are you reusing the stock pistons? Why not get pistons for 6.125 rods?
Yes that kinda deck height is way to much.
Old Feb 21, 2016 | 07:42 AM
65standard's Avatar
I have new speed-pro pistons with a 1.325 compression height.
I didn't know there were Pistons made specifically for the longer rods. I'm pretty much locked into the 6.100 rods. I really wanted Manley rods, but I can't find them in the right 6.100 with .944 pin. Scat and Eagle were the only two companies that stock these.
Old Feb 21, 2016 | 10:48 AM
JakeFusion's Avatar
Super Hulk Smash
Compstar makes one. It's worth it over the others. CSC6100DS6A2AH
Old Feb 23, 2016 | 05:38 AM
uraloser2me2's Avatar
I ended up going with the eagle rods in my new build. The scat rods are a new part and will not be available til mid march or later.
Old Jun 22, 2016 | 07:34 PM
Jarrett Dixon's Avatar
Did u have a problem running the 6.100 rods with the 1.325 compression? I'm building the exact set up. Lq4 with speed pro flat tops. How much are the out the hole?
