Best resource for head swap instructions?
I've never done it before, so really I just want to make sure I don't have any nasty surprises while going through the process. That write-up looks really good with torque specs/sequence, which thread locker to use, etc.
While I'm at it, I'm also doing several other things. This isn't a complete list of parts, just the main components.
-Head swap
-Change headers
-Poly motor mounts
-LS6 valley cover
-FAST 102
So what's the best order here? My thinking is this:
1. Misc stuff - drain radiator and oil, remove air lid and intake manifold etc.
2. Remove headers and Y
3. Remove Heads, clean block, remove valley cover
4. Swap motor mounts
5. Reinstall valley cover
6. Reinstall heads
7. Reinstall headers, Y
8. Reinstall intake, fluids
Does anything look really out of place? I just assumed motor mounts would be easiest when I have basically everything out of the way.
this is a useful site.
I recommend spending money on these two items. Vacuum out the coolant with a shop vac and 7-11 straw, or blow out the coolant with compressed air.
Then run these through until nothing comes out anymore.
