LS1 Removal from 2004 GTO
What I have is a 2004 GTO and it's LS1. My kiddo recently totaled it, ripping off the front right and rear left wheels, bending the frame and a handful of other things. Fortunately, everything under the hood is in good condition. What I want to do is pull out the LS1 from the GTO and put it in a 74-77 Corvette (yet to be purchased).
I have seen a handful of videos on removing the engine on camaros and vettes, and they all remove it from the bottom. In my case, I don't have a lift to use, just jack/jackstands and cinder blocks, and i don't think its a smart idea to come through the bottom when most of the front right suspension has been destroyed. Pulling from the top seems like the best option, plus since the car is dead to me, removing or cutting body parts isn't out of the question.
My questions:
I have a cherry picker with leveler, but not 100% sure where to secure the bolts.
I have already disconnected most of the wires and harnesses and hoses, will VATS be an issue when I move it to the new car? If so, what are my bypass options? Again since this will be going into a project and most of the components in the original work, I can scavenge what is needed.
Any other gotchas?
In terms of mounting points for the load leveler, I use four M10x1.5 holes on the cylinder heads. There is one hole on each face of the head. This centers the load leveler over the motor. You can leave the transmission connected or get under the car and pull it.
had zero issues. once you get the radiator / fans, and accessories out
of the way, you have tons of room to pull it.
exhaust ( rearward of headers ), and trans separately.
then i moved back up to the engine and removed the
rad / fans / accessories. then removed the intake / tb
assembly. then i removed the valve covers and heads.
after that, you can use the trans mount bolt hole for
the rear cherry picker mount, and you'll see the front
mount hole that you can use for the front. then remove
the motor mount bolts. once your that far, get the cherry
picker and yank it out.
I didn't think to take the intake off for removal and it's a massive PITA, there's just no room behind it to get to anything. I made damn sure I left it off when I reinstalled the motor though and it was much easier.
I used a block and tackle from a beam under the house with a chain diagonally across the heads both to remove and install which isn't ideal but it's do-able. If you have easy access to an engine crane and leveller it will make life much easier, good luck with it.
Jason.
