Comp degree help
Old Feb 16, 2016 | 10:46 PM
rayfrausto's Avatar
Default Comp degree help
Hey guy I'm ready to degree my cam right now just got done installing it. Only thing got me stuck right now is getting the comp ls crank socket over my oil pump drive gear! It is very tight I don't see how it goes over it? I have the comp ls specific degree kit. Any advice from anyone who has use the comp cams socket?
Old Feb 17, 2016 | 08:48 AM
rayfrausto's Avatar
Anyone?
Old Feb 17, 2016 | 07:32 PM
gtotoocool1's Avatar
I didn't have a problem with mine,are there any burrs on the crank sproket that might be causing a problem?
Old Feb 18, 2016 | 09:43 AM
rayfrausto's Avatar
Everything look fine i just can't get it to physically fit over oil drive gear. I went ahead and degreed it with crank bolt and washers to hold wheel. Little dissapointed
Old May 19, 2016 | 09:20 PM
SSmafia's Avatar
I'm having this same issue. Going to swap the socket out at jegs for another one. Maybe it's an issue with the machining of the socket.
Old May 21, 2016 | 05:56 PM
SSmafia's Avatar
UPDATE: Went to jegs and exchanged sockets. The new one fits. The old one was not machined correctly. Sucks I had to go through that.
Old May 21, 2016 | 07:10 PM
1970camaroRS's Avatar
Comp quality control strikes again.
Old May 22, 2016 | 07:57 PM
jayyk31's Avatar
I just had the same problem. I had to take off the crank key because the jp performancs oil pump drive gear is machined different than stock. But it worked perfect when I took off the crank key.
