LS1 Oil Pressure
On a cold winter day I sit right at around 60 psi cold idle. Usually hovers a bit above that until the oil warms.
With a fully warm engine I'll be between 38-42 psi at idle.
Mine has 163k on the clock.
Should you be worried about it? I dunno. I've seen oil pressures all over the place in these cars. As long as it rises with the RPMs in a satisfactory manner, I wouldn't worry.
This is normal for an engine with that many miles and still well within the safe range. The reason for the pressure drop is
- Oil gets thinner as it warms up
-Oil get thinner as you put running hours on it
- Parts expand as they heat up so tolerances open up as the engine comes up to running temperature
- Tolerances open up as parts wear.
GM service manual says at operating temperature minimum pressures.
6 psi @ 1000 rpm
18psi @ 2000 rpm
24psi @ 4000 rpm
anything under 6psi you will see the oil light come on and probably warning light to check guages.
As for the original question your oil pressure does seem a bit on the low side. With the mileage I don't suppose its too bad. Also early LS motors didn't have the greatest oil pump.
If you wanted to do preventative maintenance you could buy a new oil pump and put on a new o-ring. Or just leave it alone until its time to rebuild the motor.
I'd certainly keep an eye on them from now on to ensure they don't get any worse, but those are plenty to maintain a healthy engine. Maybe do an oil change with w40 oil next time.
With the stock pump I was getting a little under 40 PSI hot idle, but I was also running 0w-40, now I'm running 5w-30.
Also, could a leaking o-ring also cause the needle on the dash gauge to 'twitch', or flutter at full hot idle, even if the pressure is showing within the OK specs (~35-40 psi)???
Also, wouldn't the petroleum distillates (listed as FIRST ingredient) in the Trans-X DESTROY what is left of the oil pump/pickup tube o-ring seal, instead of just swelling it (like ATP-205, and Blue Devil rear main seal additives would)?
the trans x stuff shouldnt hurt anything. its designed to swell the rubber seals in a transmission, so it wont hurt the o ring.
