What heads will go with this cam?
Old Feb 20, 2016 | 05:31 PM
MsDasnake's Avatar
Default What heads will go with this cam?
What heads will go good with this cam? Or could I just port the stock 241 heads and get good results?
comp 54-412-11
Lift: .522''/.529''
Duration: 265°/271°
Lobe Separation Angle: 114°
Engine also has a 92mm fast intake, longtube headers, and slp lid
Old Feb 20, 2016 | 06:21 PM
HCI2000SS's Avatar
You could port the 241's or get a different. It's gonna make power either way
Old Feb 21, 2016 | 09:08 PM
kinglt-1's Avatar
all depends on budget and goals. that cam with ported 241's could get you 420whp depending on how well the heads are worked.
Old Feb 22, 2016 | 06:04 AM
Felix C's Avatar
212/218 at .050.
with that low lift just a basic valve and mill on the 241s will do.
