Piston to Valve Clearance Issues...
1. The thicker gasket will widen the quench distance quite a bit. Not sure if you will be able to run timing required to maximize power. Best answered by someone who does tuning a lot, but likely not an optimum solution.
2. You could use an adjustable timing set and move the cam enough to open the exhaust clearance. Issues here are the timing chain will stretch some with time and may shift the clearance to a lower value. You may also lose a little power with the cam shifted.
3. You could swap out for a different cam, not sure what you are running. One with a less aggressive lobe might open up clearance to an acceptable value while maintaining the same duration you currently have. Conversely, you could also get a cam that starts closing the exhaust a bit earlier to attain the clearance.
4. You could go with different heads, something I assume you really don't want to do.
5. You could really stiffen up the valve train and run as is (a risk). Stiff pushrods (3/8) and good springs will help keep things in check.
