is mechanic yanking my chain?
The 97-99 LS engines had a supposedly weaker rod bolt than the 00+ engines. There is a lot of talk on this site about swapping them to ARP or Katech.
I had a 98 LS1 engine in my car prior to the LS2 swap and I was wary at first but eventually got to the point I was spinning the engine 6700rpms regularly without issue. The engine is still in a friend's car doing fine.
It's doubtful the dyno operator will care one way or the other.
To replace the rod bolts properly it's debated the rods need to be resized. Some people say yes, some people say no.
Also, I asked the same question before my build. I was told not to worry about, and run the **** out of it
