Oil Pump Failure with pics.
Anyone ever see a pump fail like this?
Talked to the vendor I bought the pump from and they don't think the pump was at fault but I don't think would admitted it if it was.
If you went from 30 down to 0 THEN heard the bearing noise, I would tend to agree with you in that the oil pump failed to deliver proper oil pressure thus damage happened. But if the oil pump kept building oil pressure throughout the whole ordeal what makes you think that was the culprit? Just because it has some marks on it?
#1 rod bearing is pretty much the last thing to see oil pressure.
After the build and break-in, did you change the oil & filter?
Did you cut open the filter?
Or maybe the pump was dry on start up?
Those areas obviously got hot at some point.
