Help!!!!!
Old Mar 1, 2016 | 07:56 PM
Brandon's98Z's Avatar
Default Help!!!!!
Hey Everyone, ran into a problem tonight while throwing my motor together. Ill start from the top. its a gen 3 5.3 that was bored 30 over, factory style forged 30 over pistons, scat rods, and ls1 crankshaft. the problem is that I am having ptv clearance issues. so here are the cam specs
bullet racing cam
.226/.234 @.50 .590/.590 115+4. 7.400 push rod, .650 pac springs, stock rockers, cloyes timing set put on at 0 degrees.
I'm pretty new to the ls stuff so I am wondering why I am having the ptv issues, plan on calling bullet tomorrow just thought I would see if anyone here could shed some light on it.
Old Mar 1, 2016 | 08:04 PM
Aaron1989's Avatar
bullet racing cam
.226/.234 @.50 .590/.590 115+5. 7.400 push rod, .650 pac springs, stock rockers, cloyes timing set put on at 0 degrees.
Stock heads?
Old Mar 1, 2016 | 08:06 PM
yes stock 317 heads with ls9 gaskets .51 compressed
Old Mar 1, 2016 | 08:42 PM
brobinson216's Avatar
Flat tops pistons with valve reliefs?
What measurements are you coming up with? How are you measuring?
You've left out a good bit of information for anyone to help.
