BTR stage 3 what to Expect
Mine was a bit sluggish down low with the 3:42's.
400whp is right in line, possibly a little more. Mine is tuned SD and my only complaint is the 1100ish rpm bucking. That will be addressed soon enough with the tuner.
Just installed a FAST 92mm, and back to the dyno it goes.
You could get a happy dyno and read pretty high, you might be bummed out. My car with a 224r cam and 1 3/4 headers with a loudmouth II made 370/365
In all seriousness though, you should be at, or above, 400rwhp with that setup. Have fun with it.
Also, RotP, I found your Viking coilover settings a few days ago on a thread and dialed them in on mine. Car hooks better than ever now!
Yeah man they've been awesome and bumps no longer make the 9 inch axle tubes slam into the exhaust pipe
Haven't had a chance to run with them at the track, but I've been looking at a Racestar setup similar to yours. Does your front end lift up a lot when you give it a hit? With the Rebound at 0 and Compression at 15, mine actually lifts a little less than before (R=10 C=7)
Mine made 402hp unlocked and 540/508 on a conservative 150 shot tune. And that's with 241's and a LS6 intake!
See I thought the same thing but with a stiff rear, even cruising around is better now. I am going to get some slicks on it soon, but I'm still on the stock driveshaft, so that needs to change as I've been putting it off. If you find a sweet spot for front settings let me know! I'll do the same back. Right now I am very content with the rear settings. I suppose the front shouldn't lift much if the rear isn't squatting.
