LQ9 cam and long lasting spring choice
I am swapping my LS1 with an LQ9. I have searched and found some good cams but keep seeing that the springs will need to be changed every 20-25k.
Are their any mild cams with a good spring that will last 50k+? I have a lot of other work to do on the car and would rather hold off if they need to be changed that soon. I doubt I'll need 50k miles worth of time but don't want to feel like I'm on the clock if I'm on another project when the time comes.
Edit: I should have mentioned, this is not my daily driver and will be mostly driven on the street and occasionally 40 miles to work in the summer.
Thanks
Thanks
You could use one of the BTR truck cams which uses the LS3 or LS6 springs which last along time. http://www.briantooleyracing.com/tru...ge-iv-cam.html
Thanks for the responses. The truck cam is a good idea, going to look into it.
For now I think I'll just sand/paint the block and throw the LQ9 in as-is. I don't want to hold off on installing the engine. The summer is coming and I don't even know how well the 4l60e does passed 2nd gear. Got to leave enough time to swap the trans if I need to.
