Need new 5.3 rods
Old Mar 11, 2016 | 09:14 PM
moekluse's Avatar
Default Need new 5.3 rods
I'm building a 1000hp+ motor and I just got my heads and block back. Using 317 heads, 8.3:1 dish weisco pistons (floating ring) and I'm looking for some good strong rods. Are l33 and lm7 crankshafts the same? Probably different reluctor but could I use a k1 industry rod on the gen 3 which used the press fit?
It's hard to find the rod in 6.098 so will 6.1 work with a .51 head gasket?
Old Mar 11, 2016 | 09:57 PM
panic's Avatar
Can't answer your question, but 5.3 is 3.78" bore, yes?
Doesn't the 317 (L92 style rectangular) head require 4.00" or larger bore?
Old Mar 11, 2016 | 10:08 PM
xdanny510x's Avatar
Nope they fit 5.3 bore as well..
Old Mar 11, 2016 | 10:14 PM
slogo's Avatar
317's are not L92 style rectangular ports.
Old Mar 12, 2016 | 10:24 AM
panic's Avatar
Thanks, I KNEW there had to be more to it! I cut-n-pasted a table of head castings vs. Gen and port shape from somewhere, evidently it's got typos in it.
Best of luck with your project.
Old Mar 12, 2016 | 12:51 PM
KCS's Avatar
KCS
Moderator
What PN piston are you using?
Old Mar 12, 2016 | 12:55 PM
moekluse's Avatar
.945 pin
Old Mar 12, 2016 | 12:56 PM
moekluse's Avatar
Thank you
Old Mar 12, 2016 | 06:42 PM
uraloser2me2's Avatar
The only press fit Aftermarket 6.100 rod with a .945 pin I have seen is the Scat I beams. The k1's are for .927 pins and the Scat and Eagle h beams are all for floating pins. Also the Scats are not available yet.
Old Mar 12, 2016 | 06:45 PM
moekluse's Avatar
My pistons are floating
Old Mar 12, 2016 | 06:58 PM
Sorry when you said 3 gen I thought you were talking about the press fit pistons. If you have .945 floating pins Scat SCA-66100945A or Eagle ESP-6100M3D2000 are the only 2 I have seen. I bought the eagle for my build because the Scats are a new product and they kept pushing the release date back.
Old Mar 12, 2016 | 07:00 PM
moekluse's Avatar
Will they hold 1000hp? I saw some k1 rods that would fit I just want some rods that won't blow the motor up at my type o boost
Old Mar 12, 2016 | 07:07 PM
KCS's Avatar
KCS
Moderator
.945 pin
I was asking what Part Number.
You're going to have very few options with a .945" pin. Most of the rods are for a .927" pin.
Old Mar 12, 2016 | 07:20 PM
moekluse's Avatar
Ah yea I see a few but not too much
