"stealth" cam
Old Mar 13, 2016 | 03:41 PM
fastbird02's Avatar
Default "stealth" cam
hey everyone,
I am looking for a "stealthy" cam for my forged lq4 short block, 243 heads, and a ls6 intake. off the shelf is fine. i also will be running a 200hp wet plate, but hardly ever. right now i am leaning towards either a gt2/3, or a gt11. but i am open to other suggestions.
the car is a daily driver with a yank 3600 converter.
thanks for your help,
Bruce
Old Mar 13, 2016 | 04:17 PM
A.R. Shale Targa's Avatar
My former cam was an EPS 218/226. 117ls + 3 deg and idled completely stock in a 10.75:1 LS1. Pulled strong to 6700 with hollow valves and dual springs
Old Mar 13, 2016 | 09:40 PM
Cajun ELESS-ONE's Avatar
have you done any research on the z06 cam?
Old Mar 13, 2016 | 10:07 PM
fastbird02's Avatar
the z06 cam seems like best bang for the buck, i am just wondering how much better i can do with the same drive-ability and tame idle.
Shale, any idea how much power you picked up? i have read that the gt2/3 will net around 35-40hp alone. i am aiming for 500whp w/o n2o. im thinking with the ported 243s in my lq4, i should be getting close depending on cam selection. this is no dyno queen so if i dont hit 500 oh well, rather have a better curve than a peak number...
Old Mar 13, 2016 | 10:41 PM
spawne32's Avatar
LPE GT2-3 for sure
Old Mar 13, 2016 | 11:17 PM
kinglt-1's Avatar
there are much better options then the LS6 cam. you are not going to come close to 500whp with a small cam and 243's.
Old Mar 13, 2016 | 11:23 PM
Yeah getting a 364 to 500whp would take a cam that would definitely rumble. So the sleeperish route will limit you to the 430-450 range depending on how well your heads turn out
The LPE 2-3 is pretty tame even in a LS1 so with more inches and compression you could creatively sneak a 224/228 past most people with a wider 116 lobe separation and setting the idle at 950
Old Mar 14, 2016 | 01:59 AM
viaotone's Avatar
Old Mar 14, 2016 | 08:32 AM
redtan's Avatar
Good thinking. I doubt you will even hit 400rwhp with that combo.
Old Mar 14, 2016 | 09:23 PM
fastbird02's Avatar
well i guess a little lope isnt a bad thing... lol. with those goals in mind, whats a "tamish" cam that would get me close? or should i be looking into a custom cam, or am i just out of my mind? whats a realistic goal?
Old Mar 14, 2016 | 10:50 PM
kinglt-1's Avatar
you need a 228/232 Titan from Cam Motion for that 6.0. It will sound good, make great power, and have great Street manners.
Old Mar 15, 2016 | 02:53 PM
fastbird02's Avatar
ya i guess "street manners" is a good term for what i am looking for. i like the fact i can start my car and go. (not that i do) any other suggestions? that cam sounds like a good option...
Old Mar 15, 2016 | 02:59 PM
thunderstruck507's Avatar
My roommate has that cam in his 6 speed ls1 trans am. It will be even more tame in your 6.0
Sounds like a great choice for your application.
Old Mar 15, 2016 | 03:53 PM
Russ K's Avatar
If you want a tame idle, then use a camshaft with 0* overlap or less.
The Cam Motion Titan 3 has 0* overlap.
Russ Kemp
